Cables altavoces X-Type
Publicado: 02 Mar 2015 20:36
Hola compañeros.
Voy a ponerme a cambiar los altavoces de mi X-Type y trasteando para ver que me hace falta me encuentro con la siguiente lista que se corresponde con el MY del coche:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|green/orange |+ |ignition harness |
| SECOND IGNITION|black (key sense) |+ |ignition harness |
| ACCESSORY|green/white |+ |ignition harness |
| POWER LOCK|green *1 |- |gry plug, pin 16 @ GECM *2 |
| POWER UNLOCK|blue *1 |- |gry plug, pin 14 @ GECM *2 |
| LOCK MOTOR|yellow/black | |grn plug, pin 3 @ GECM *2 |
| UNLOCK MOTOR|white/green | |brn plug, pin 5 @ GECM *2 |
| DISARM DEFEAT|white/black | |brn plug, pin 1 @ GECM *2 |
| PARKING LIGHTS +|red | |pin 5 @ headlight switch |
| PARKING LIGHTS -| | | |
| HEADLIGHTS|green/black |- |pin 13 @ headlight switch |
| DOOR TRIGGER|black/pink |- |gry plug, pin 3 @ GECM *2 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|brown |- |gry plug, pin 22 @ GECM *2 |
| HOOD PIN|black |- |blu plug, pin 21 @ GECM *2 |
|TRNK/HTCH RELEASE|blue |- |brn plug, pin 16 @ GECM *2 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK| | | |
| TACHOMETER|green/stripe | |any ignition coil |
| SPEED SENSE|blue |8 |grn plug, pin 20 @ GECM *2 |
| BRAKE WIRE|green/white |+ |brake pedal switch |
| HORN TRIGGER|black |- |brn plug, pin 14 @ GECM *2 |
| WIPERS|wht/grn(L),wht/blk(H|+ |steering column |
| LF WINDOW UP/DN|*3 | | |
| RF WINDOW UP/DN| | | |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
| SUN RF OPN/CLOSE|*3 | | |
| SUN ROOF LIMIT| | | |
| RADIO 12V|brown/white |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
| RADIO ILLUMINATE|orange (dimmer) |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|white - yellow | |radio |
| RF SPEAKER|wht/red - yel/red | |radio |
| LR SPEAKER|wht/blu - yel/blu | |radio |
| RR SPEAKER|wht/grn - yel/red | |radio |
Lo marcado en rojo es lo que nos ocupa, los cables que llegan a los altavoces. La pregunta es cuál es el positivo, los blancos o los amarillos o en el peor de los casos una combinación de ambos???
Si alguien me saca de dudas se lo agradecería.
