Llamadas a revisión XF. Próximo a caducar
Publicado: 31 Ago 2012 10:02
TECHNICAL BULLETIN No: K061
Issue: 2
Date: 03 DEC 2010
SERVICE PARTS WARRANTY BODY SHOP
NOTE: The information in Technical Bulletins is intended for use by trained, professional Technicians with the knowledge, tools, and
equipment required to do the job properly and safely. It informs these Technicians of conditions that may occur on some vehicles, or
provides information that could assist in proper vehicle service. The procedures should not be performed by 'do-it-yourselfers'. If you are
not a Dealer, do not assume that a condition described affects your vehicle. Contact an authorized Jaguar service facility to determine
whether this bulletin applies to a specific vehicle.
©2010 Jaguar Land Rover North America LLC Page 1
THIS SERVICE ACTION IS VALID FOR A LIMITED TIME ONLY
AND WILL EXPIRE 30 NOVEMBER 2012
ISSUE '2' CHANGES ARE HIGHLIGHTED IN GRAY
SECTION: 100
Service Action: XF Assurance Program
AFFECTED VEHICLE RANGE:
XF (X250) VIN: R37598 - R85205
Model Year: 2010 - 2011
CONDITION SUMMARY:
Situation: To ensure certain 2010 - 2011 model year XF vehicles are supplied to customers with the very
latest software and parts to enhance the vehicle owner's experience, certain vehicles within the affected VIN
range require a minor control module software updates and replacement parts installed.
The control module updates are:
• Front door control modules / Rear glass comfort stop - update to prevent rear door glass 'bounce'
• Car Configuration File - update to ensure global open feature is fully functional
The issues requiring new parts or repair are:
• Driveshaft heatshield (Supercharged only) - install a new heatshield to prevent heat damage to center
joint diaphragm
• Cross joint at rear windshield - resealed to prevent water ingress into the luggage compartment
Action: Dealers are required to HOLD all affected vehicles in the VIN range above that are in their control
and refrain from releasing the vehicles for new or used vehicle sale pending completion of the rework action
detailed in this Technical Bulletin. Affected vehicles in the hands of owners should be repaired at the next
available opportunity. At the time of customer appointment, ensure that all outstanding service campaigns
for each individual vehicle are identified and allocate sufficient time and resources to complete all
campaigns.
For vehicles in dealer inventory, this Service Action should be performed in conjunction with the vehicle Pre-
Delivery Inspection (PDI). Vehicles in dealer inventory must be updated prior to customer handover.
Issue: 2
Date: 03 DEC 2010
SECTION: 100
CONDITION SUMMARY:
joint diaphragm
campaigns.
