Hola a todos, tengo un Jaguar XK del 2009,y no logro encontrar en ningun sitio que reparto de peso tiene entre el eje delantero y el eje trasero.
Si podeis ayudarme os lo agradeceria.
Saludos!!
REPARTO DE PESOS JAGUAR XK
DON GATO V8
Re: REPARTO DE PESOS JAGUAR XK
a ver como queda...
Technical specifications
L
Technical specifications ENGINE SPECIFICATIONS
WEIGHTS
Note: The maximum permitted luggage compartment load can be exceeded, provided the
requirements regarding the maximum permissible axle weights and tyre pressures are followed.
1 GVW = the maximum permissible weight of the vehicle, including all passengers and load.
5.0 V8 normally aspirated 5.0 V8 supercharged
Capacity 5000 cm³
(305 inch³)
5000 cm³
(305 inch³)
Bore 92.5 mm
(3.64 inch)
92.5 mm
(3.64 inch)
Stroke 93 mm
(3.66 inch)
93 mm
(3.66 inch)
Compression ratio 11.5:1 9.5:1
V8 5.0 normally aspirated V8 5.0 supercharged
Coupe Convertible Coupe Convertible
Kerb weight (no options fitted) 1595 kg
(3516 lb.)
1635 kg
(3605 lb.)
1665 kg
(3671 lb.)
1715 kg
(3781 lb.)
Front axle kerb weight 850 kg
(1874 lb.)
852 kg
(1879 lb.)
900 kg
(1984 lb.)
909 kg
(2004 lb.)
Rear axle kerb weight 745 kg
(1642 lb.)
783 kg
(1726 lb.)
765 kg
(1687 lb.)
806 kg
(1777 lb.)
Gross Vehicle Weight (GVW)1 2035 kg
(4486 lb.)
2075 kg
(4575 lb.)
2080 kg
(4586 lb.)
2120 kg
(4647 lb.)
Gross front axle weight 1015 kg
(2238 lb.)
1020 kg
(2249 lb.)
1050 kg
(2315 lb.)
1050 kg
(2315 lb.)
Gross rear axle weight 1090 kg
(2403 lb.)
1125 kg
(2480 lb.)
1095 kg
(2414 lb.)
1130 kg
(2491 lb.)
Maximum luggage compartment
load with passenger and driver
28 kg
(62 lb.)
28 kg
(62 lb.)
28 kg
(62 lb.)
28 kg
(62 lb.)
L
WEIGHTS
Capacity 5000 cm³
(305 inch³)
5000 cm³
(305 inch³)
Bore 92.5 mm
(3.64 inch)
92.5 mm
(3.64 inch)
Stroke 93 mm
(3.66 inch)
93 mm
(3.66 inch)
(3516 lb.)
1635 kg
(3605 lb.)
1665 kg
(3671 lb.)
1715 kg
(3781 lb.)
(1874 lb.)
852 kg
(1879 lb.)
900 kg
(1984 lb.)
909 kg
(2004 lb.)
(1642 lb.)
783 kg
(1726 lb.)
765 kg
(1687 lb.)
806 kg
(1777 lb.)
(4486 lb.)
2075 kg
(4575 lb.)
2080 kg
(4586 lb.)
2120 kg
(4647 lb.)
(2238 lb.)
1020 kg
(2249 lb.)
1050 kg
(2315 lb.)
1050 kg
(2315 lb.)
(2403 lb.)
1125 kg
(2480 lb.)
1095 kg
(2414 lb.)
1130 kg
(2491 lb.)
28 kg
(62 lb.)
28 kg
(62 lb.)
28 kg
(62 lb.)
28 kg
(62 lb.)
DON GATO V8
Hola, mil gracias por la respueta. Olvidé poner que es un JAGUAR XK CABRIO con acabado portfolio. Entiendo que por los refuerzos que lleva tal vez tenga un reparto peor que este 53%/47%.
Muchisimas gracias de veras!!!.
DON GATO V8
¡¡Lo encontre!!.
52% delante, 48% detras.
SALUDOS JAGUARISTAS!!!!
